Message 1 of 7
Slow broadband in evenings
Hi All
Can someone please help me possibly raise a case to wholesale to check for exchange congestion?
I have FTTC. My bb speeds are around 70-80Mbps during the day and have started to drop to around 20-40Mbps in the evening.
The line is testing ok. No noise on quiet line test and tested both in SSFP and filter in the test socket.
I have ran wholesale speed tests in the day and the evenings and uploaded results. This was tested on my laptop using a wired connection. I'm about 30m away from the cab which is a copper connection.
Hope someone can help
Gareth
6 REPLIES 6
Message 2 of 7
Re: Slow broadband in evenings
I have asked mods to check your exchange and cab for possible congestion.  They will post back here but are busy so could be a few days
Message 3 of 7
Hi @talbius,
We'll check into this to see if our suppliers are showing any congestion.
I'll drop you a private message so we can pick it up for you
DanielS
Message 4 of 7
Thanks DanielS, will do that now
Message 5 of 7
Line tested with only hardwired laptop connected, all other cables and wifi devices disconnected. Results attached.
Cheers
Message 6 of 7
Hi all
Any update on this please? My line is testing 8mb download speed on the lan this evening, really frustrating.
Cheers
Message 7 of 7
Did you reply to the mod PM?
