Message 1 of 6
Slow broadband
I currently have b/b speeds of download 0.2! upload 0.3! 12 May, can’t contact bt for explanation, utter shambles!
5 REPLIES 5
Message 2 of 6
Re: Slow broadband
@2019
Welcome to this user forum.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 3 of 6
Re: Slow broadband
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
is the hub dropping connection?  are you using wifi or ethernet connection
Message 4 of 6
Re: Slow broadband
Sorry to butt in - HOW to add tech log/ other diagnostic files to a post here?
Message 5 of 6
Re: Slow broadband
Try using a different a DNS server maybe? you can try 8.8.8.8 which is the default google dns server
Message 6 of 6
Re: Slow broadband
using the forum help explains how to post an image
https://community.bt.com/t5/help/faqpage/faq-category-id/images/title/images
please stick to your own thread to avoid confusion
