Message 1 of 18
Upload speed deterioration
Hi
Moved to remote large rural property 9 months ago.
BT explained Infinity was no longer available but I should be ok for 4m download 1m upload speeds.
All ok until ? lockdown began - download has remained constant but upload collapsed to under .5  Lots of connection etc problems - it's not a wifi issue - no better on cable connection via TP-Link over mains to hub.
The BT speediest result says all fine BUT they only quote the download speed not the upload..
Am trying to add my speediest history and Hub tech log files but struggling how to...
17 REPLIES 17
Message 2 of 18
Re: Upload speed deterioration
Hub tech log info:
Tags (1)
Message 3 of 18
🙂 for "speediest" please read "Speedtest" !!
Message 4 of 18
enter your phone number and post results  remember delete number
Message 5 of 18
Sadly i can't access the test result because I inadvertently jumped the gun and clicked Report problem so it just tells me there is an Open fault I did just do the Quiet Line test - all clear
Message 6 of 18
I do have SpeedTest results from Mac app - any use?
Message 7 of 18
Message 8 of 18
just need to see dslchecker results to make sure adsl2 available as you are on adslmax with max up speed of 448kbps
it's not btspeedtster results I am looking for
Message 9 of 18
Message 10 of 18
If relevant we are a few Kms from cabinet...
