Message 1 of 4
Slow upload speed
Good Evening,
Hoping someone can help. When I took out my BT contract I was promised 20mbps upload but I am only getting 10mbps. I have posted below the stats from the router. Could someone advise the max down and up speeds I can expect from my line please:
Product code:Smart Hub 2
Serial number:+091298+2051008577
Firmware version:v0.24.04.11017-BT
Firmware updated:Wed Jan 27 06:59:48 2021
Board version:R01
GUI version:1.71 05_06_2020
DSL uptime:0 days,07 Hours44 Mins19 Secs
Data rate:9.995 Mbps / 50.98 Mbps
Maximum data rate:15.004 Mbps / 60.134 Mbps
Noise margin:9.6 / 6.3
Line attenuation:4.8 / 15.7
Signal attenuation:4.8 / 14.9
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:352.4 MB Uploaded / 2.0 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:30:B1:B5:0D:0F:E6
Software variant:-
Boot loader: 0.1.7-BT (Thu Nov 30 09:45:22 2017)
3 REPLIES 3
Message 2 of 4
Re: Slow upload speed
can you go to MYBT and check which package is shown as it looks like Fibre 1 with max 10mb up speed
from your stats fibre 2 is pointless as you down speed attainable is only 60mb so likely you will be less than that unless you specifically wanted a faster up speed that the 10mb no point in paying extra for something you cannot reach
Message 3 of 4
Hi there,
Thanks for your reply. My BT shows Fibre 2 but only shows 10mbps upload speed. Is there any way I can change the upload to be 20mbps please.
Message 4 of 4
try phoning the options team 0800800030 and see if they can help failing that need to phone CS 150
