Message 1 of 13
Speed Dropped Off
When we first moved into our home the max speed the ADSL checker said we could could have was 80 down and 20 up, and the hub reflected that. However over the last few months the speed has dropped to 49 down and 12 up with a noise margin of 9db if I'm reading it right. Can our line be reset or something?
12 REPLIES 12
Message 2 of 13
Re: Speed Dropped Off
If you want assistance from the community you need to give us a little more info.
Post the hub connection stats for HH5 Troubleshooting/helpdesk. Fot HH6/Super hub Advanced settings/technical log/information.
Do a quiet line test 17070 option 2 best with corded phone.
Message 3 of 13
Hi there, the home hub info is as follows and the dial test was all fine.
Message 4 of 13
connection time is only 8hrs was that a manual reset or hub dropping connection?  have you noticed the hub dropping connection often
Message 5 of 13
It was a manual reset
Message 6 of 13
The internet doesn't drop out that much, only once a month or something like that
Message 7 of 13
It looks like you are in a banded profile perhaps due to the connection dropping more frequently either in the past or what you have noticed recently. Once a month would not cause that to happen.
Message 8 of 13
So would a line reset put this back to how it should be? If so what details are needed to do this?
Message 9 of 13
If you can maintain a stable connection with no drops or resets then DLM should reduce noise margin and increase speed but could take a few weeks
Message 10 of 13
Since it's been like this for months and our 'guaranteed minimum' is 64, could the line be reset anyway?
