Message 1 of 10
Speeds pegged at 30Mbps
Hi,
I've had trouble with my speed ever since I signed up 12 months ago. I never seem to be able to get a steady 46Mbps which is my stay fast guarantee. It usually drops to 25Mbps for a few weeks, i contact LC, they send multiple engineers, it magically returns to 50Mbps for a few weeks then the cycle starts over again. I have been locked at 30Mbps for about a moth now, upload speed has dropped significantly as well. LC are not available so i'm asking for some help on here.
I have uploaded a screen of my stats.
Thanks.
9 REPLIES 9
Message 2 of 10
Re: Speeds pegged at 30Mbps
Can you post the router stats as well?
Message 3 of 10
Besides posting the connection stats could you also do a quiet line test, 17070 option 2, best with corded phone.
Message 4 of 10
Router stats are
 Connection status:
 Connection type:
Fibre Broadband (VDSL)
 Downstream sync speed:
32.40 Mbps
 Upstream sync speed:
3.69 Mbps
 Network uptime:
0 Days, 0 Hours 3 Minutes
 Broadband IP address:
81.153.136.174
 Default gateway:
172.16.14.121
 Primary DNS:
81.139.57.100
 Secondary DNS:
81.139.56.100
 System uptime:
1 Days, 0 Hours 48 Minutes
 Serial number:
+084319+NQ90758601
 Firmware version:
SG4B1000E020
 Firmware updated:
31-Mar-2020
 BT Wi-fi status:
Active
Message 5 of 10
I only have a cordless phone but doesn't seem noisy.
Message 6 of 10
is the quiet line test silent no noise at all?
stats from advanced settings then technical log information please
Message 7 of 10
No noise at all.
Product name:
BT Hub 6A
Serial number:
+084319+NQ90758601
Firmware version:
SG4B1000E020
Firmware updated:
31-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 0 Hours 55 Minutes 43 Seconds
Data rate:
3.69 Mbps / 32.40 Mbps
Maximum data rate:
25593 / 74541
Noise margin:
23.2 dB / 15.2 dB
Line attenuation:
22.1 dB
Signal attenuation:
14.8 dB / 22.1 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
18 MB Uploaded / 123 MB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-PH5P
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-PH5P
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
00:CB:51:A7:56:CF
Software variant:
Boot loader:
9.2.0
Message 8 of 10
After a bit more reading I'm assuming I'm on a banded profile due to the instability I've had in the last 12 months, can someone help me get out?
Anonymous
Not applicable
Message 9 of 10
@jjshacks13wrote:
Router stats are
 Network uptime:
Network Uptime 3 mins? do you not leave your router powered up 24/7 as advised?
https://community.bt.com/t5/Archive-Staging/Should-I-leave-router-on-24-7/td-p/1278317
Message 10 of 10
Yes it's on 24/7 I was doing checks with it being plugged into the master socket.
