Message 1 of 16
Sport App
When trying to access live content on sport app get message LP110. Factory reset home hub but made no difference.
15 REPLIES 15
Message 2 of 16
Re: Sport App
You're not the only one raising this. I've asked one of my colleagues to investigate, as it suggests an issue at our end.
Message 3 of 16
Re: Sport App
Are you using an Amazon tablet @Keithr5 ? We don't support Amazon tablets, which is why this wasn't picked up in testing.
We're trying to find a workaround, but it may require another client update which will take a few days.
Message 4 of 16
Re: Sport App
Same here. Has been working (fairly) flawlessly on my Amazon Fire 10 tablet for months now, all of a sudden getting LP110 errors on all live game (not on on demand stuff). Restarted / uninstalled / logged out and in etc.
Message 5 of 16
Re: Sport App
You can add me to the list of customers who have Amazon tablets (both 7 and 10") that suddenly decided BT sport live content was unusable... LP110 error
Message 6 of 16
Re: Sport App
Had an hour which I'll never get back onto technical assistance which I think was probably in India, eventually was good the fault was with my internet connection which was a load of rubbish. All has been working perfectly but BT have now decided live content to Amazon tablets no longer available. My contract finishes shortly and unless this is resolved quickly I will cancel
Message 7 of 16
Re: Sport App
You have read message 3 right? Why would they be trying to fix it if they'd decided to no longer offer it?
Message 8 of 16
Re: Sport App
You obviously haven't read message 3 correctly
Message 9 of 16
Re: Sport App
Due to major football matches on this week, we're unable to release the fix to everyone in the Play Store.
We'll be releasing to the beta group either later today or tomorrow - if you want the fix sooner, you can join the beta using the button shown half way down the BT Sport app details page in the Play Store.
Otherwise, it'll most likely be next week before it can be released to everyone.
In the meantime, we're updating the LP110 error message to something a little less obtuse.
Message 10 of 16
Re: Sport App
Update: we've managed to implement a workaround at our end. Normal service is resumed.
