Message 1 of 5
Strange addition to the telegraph pole
hi, can anyone shed any light as to what this is on the side of the telegraph pole, looks like they are doing a few in the street
thanks
4 REPLIES 4
Message 2 of 5
Re: Strange addition to the telegraph pole
It's a joint enclosure to house the join between the two cables.
Message 3 of 5
It could be a SASA or just a Fibre Track Joint. Without seeing inside it it’s difficult to say.
Message 4 of 5
The black boxes at the bottom of the picture is used for FTTP.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 5
Thanks for the replies, openreach turned up 30 minutes later, and did indeed confirm they were starting to fit fibre to our street (yay!)
