Message 1 of 9
Sync Speed
im only getting 4mbps/1up i usually get 6-8 on this new fiber. before i had 10down on adsl...anyway can a mod here please reset my sync speed. thank you!
8 REPLIES 8
Message 2 of 9
Re: Sync Speed
okay getting worse, this is just unusable now
Downstream sync speed:
2.917 Mbps
Please can a mod fix this
Tags (1)
Message 3 of 9
Re: Sync Speed
Enter your phone number and post results. Remember to delete phone number
the mods cannot magically make your connection better. It is quite possible that your adsl was better than your fibre connection especially if you are a long way from your street cabinet
Message 4 of 9
Re: Sync Speed
enter my phone number where?  and also a sync reset is not possible anymore? thanks for help
Message 5 of 9
Re: Sync Speed
Message 6 of 9
Re: Sync Speed
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean) James_lol_0-1597258308761.gif
6.62.71.20.82AvailableAvailable--
6.62.61.20.82AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 5.5--3 to 8AvailableAvailable--
Up to 5.5Up to 13 to 8AvailableAvailable--
Up to 4--3 to 7AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds VDSL ADSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
9.069.73
1.111.18
2020-05-042020-03-09
Message 7 of 9
Re: Sync Speed
As you can see the fibre speed are what you would expect looking at the dslchecker results so you are probably better on adsl but sooner or later you will have to move to fibre
you can contact BT 0800800030 and ask to move back to adsl2
Message 8 of 9
Re: Sync Speed
Agreed but the last few months i've been happy at 7mbps for it to randomly desync down to 2.2mbps is not what i should expect really
Message 9 of 9
Re: Sync Speed
Is there any noise on your line with a quiet line test 17070
