Message 11 of 18
Re: Upload speed deterioration
just need the dslchecker results
Message 12 of 18
Sent them on last post
SORRY didn't realise hadn't loaded
ADSL2+ is available Up to 2M downstream No upstream rate included
Message 13 of 18
Observed speeds on ADSL Max downstream 6.69 Upstream .45
Message 14 of 18
ADSL Multicast also available
Message 15 of 18
that's ok
I have asked mods if they can help get you upgraded to adsl2 which is unlikely to improve your down speed but should increase up speed by about 100%
mods are prioritising vulnerable and elderly so may take a bit longer for them to get back to you
Message 16 of 18
Should I give you the Fault report number for Mods to use/cancel?
Message 17 of 18
Hi @PJ30 and thanks for posting.
I can help with the upgrade to ADSL2. I've sent you a message so please reply to that with the details and we'll take it from there.
Cheers
David
Message 18 of 18
Thanks David - replied.
