Message 1 of 9
VIP/Big Sport/ Entertainment
I have just got new BT Pro box and VIP package which includes Sky cinema which I don't use.  If I switch to Big Sport and Entertainment plus HD bolt on will I lose access to channels 433 and 465
8 REPLIES 8
Message 2 of 9
Re: VIP/Big Sport/ Entertainment
No, if you have the HD add on you should be able to watch BT Sport Ultimate.
Message 3 of 9
Thanks for reply @DarrenK98  but on BT web Big Sport does NOT seem to include Ultimate you only get this with VIP
Message 4 of 9
@david1982 You need to also take out the HD addon for an additional £5 per month, you'll then get access to BT Sport Ultimate on the Big Sport plan.
Neil
Message 5 of 9
Thanks @NeilO that's what I was thinking but would this also include HDR channel 466
Message 6 of 9
I have both the 433 and 465 channels enabled on my BT Pro Box. I pay £15 for BT Sport and £5 for the HD add-on with includes UHD.
There are two HD add-ons which confuses the customer, the Ultra HD one and the HD one which includes Ultra HD.
Maybe someone can explain the difference between "HD & 4K add-on" and "4K Ultra HD bolt-on" ?
Message 7 of 9
Thanks @ozsat  BT doing their best to confuse me and succeeding, you have made it all a lot clearer
Message 8 of 9
HD & 4K used to be separate add on's but since the move to flexible tv with Now etc the HD add on includes 4K as well if the bb speeds are fast enough
Message 9 of 9
So I have BT Sport with HD/4K added so £15+£5.
In MyBT - I'm offered the 'Ultra HD bolt-on' too for another £5.
