Message 11 of 16
Re: Wanting to find out?
  Both on  my huawei hg612 unlocked and bt hub2 and saying attainable rate at 70 meg and upload at 20 meg.
Message 12 of 16
Phone the options team and tell them you want to upgrade to fibre 2 0800800030
Message 13 of 16
Thanks will give it a go but not confident that they will do it as when I put my address in the fibre 2 was not a option.
Message 14 of 16
As I guessed BT dont have a clue. So thats domethjng that will never get fixed. Thank you all for your help.
Message 15 of 16
In what way do they not have a clue? Did they not understand the request or did they say it wasn't possible to upgrade to fibre 2?
Message 16 of 16
Explained the situation and that I can receive the speed and all they kept doing was passing me around saying they don't know went through to multiple tech support people.
