Message 1 of 7
Website errors
Hi all,
Please can you help. I’m having some issues since last week I’m unable to get on some websites. There are some access denied error when trying to open some websites (Tesco).
please help me
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Website errors
On all or just some devices?
Can the failing device(s) access that site if you connect using your mobile phone as a hotspot?
Message 3 of 7
Re: Website errors
Yes, all devices fail but if I hotspot or use 4G then I can access the sites.
Anonymous
Not applicable
Message 4 of 7
Re: Website errors
Log into your MyBT account and disable BT Web Protect (if enabled)
Message 5 of 7
Re: Website errors
Thanks for the help. I have checked and the BT web protect was not active.
Anonymous
Not applicable
Message 6 of 7
Re: Website errors
Have you tried rebooting the hub? If that doesn't work then try a factory reset
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Message 7 of 7
Re: Website errors
Thanks you very much. I had done a restart and still had the issue. When I did a factory reset this has resolved the issue.
many thanks for your help
