Message 1 of 3
Wifi hotspot
Can I turn off or secure my Wi-fi hotspot
I recently had GFast fitted and changed the name and password which is secure, I still have a BT hotspot in my networks which is open and not secure, can this be turned off or secured so people cannot piggy bank it-or shall I leave it unsecured, if I turn this feature off or secure it does it mean I will not be able to connect to BT hotspots when I am out and about-or shall I just leave it
2 REPLIES 2
Message 2 of 3
Re: Wifi hotspot
You cannot secure btwifi but there is no access to your main home network for anyone connecting to btwifi
if you opt out of btwifi and it is turned off then you cannot access hotspots when you are out and about
Message 3 of 3
Re: Wifi hotspot
Many thanks
