Message 11 of 16
Re: Wifi not working
Try a factory reset of the hub. Press the recessed button with a pin for about 20 seconds until the lights flash.
Message 12 of 16
Thank you ! I factory reset and its working, should I still turn off smart set up?
Message 13 of 16
Definitely!!
Message 14 of 16
What does smart set up do?
Message 15 of 16
What is it supposed to do or what does it actually do?
It is supposed to help you set up newly connected devices, it actually screws up everything that tries to connect but can't launch a browser.
Message 16 of 16
Oh right turning it off now, thanks
