Message 1 of 4
access BT Cloud
How do I access BT Cloud from Office19, the Icon has disappeared since upgrading
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: access BT Cloud
Hi @doron20, welcome to the forum and thanks for your post.
Are you still unable to find the Cloud Icon? If so can you find the Cloud by searching your files?
Cheers
John
Message 3 of 4
Re: access BT Cloud
Thanks John, I found them now, the icon in the side bar disappeared when I ungraded tyhe Office App, got it now
Ron
Message 4 of 4
Re: access BT Cloud
Hi @doron20 ,
Thanks for getting back and letting us know you got this sorted. Appreciate you taking time to do that.
All the best
David
