Message 31 of 46
Re: Log in problem
Go to Tools then Account settings, click on Add mail account in the drop down box Account Actions.
Message 32 of 46
Re: Log in problem
Thanks for the update - is it preventing BT Cloud access as well ?
I'm trying to download a couple of hundred gigs of backup with no access.
Edited to add, this was in reply to Neil's update on the 2nd page of the thread.
Message 33 of 46
Re: Log in problem
@licquorice  I may have phrased my post badly but I can't use the method you show to add a new email address I can only access existing ones.
Message 34 of 46
Re: Log in problem
Thank you again for your help.
Message 35 of 46
Re: Log in problem
@Bob1001 My posts were just to describe how to create an account in Thunderbird for @@polish   If the current problem causes the inability to create a new account, there is nothing I can help with I'm afraid.
Message 36 of 46
Guys out there is email server down
Message 37 of 46
Re: Email
It certainly is and has been for some time, see post opened email is down.
Message 38 of 46
Re: Email
Message 39 of 46
Re: Email
Message 40 of 46
Re: Log in problem
They can't even get the fault message right, its IMAP not iMap which implies an Apple product.
