Message 1 of 2
My set top box is connected to the smart hub with an ethernet cable & works v well when viewing & recording progs, if I change to Halo3 does the box still connect up using the same method
1 REPLY 1
Message 2 of 2
Re: halo 3
changing to Halo 3 which is just an add on will not affect your set top box
