Message 21 of 28
Re: how to get rid of an outlook.com address which invades my btinternet resulting in unanswered pos
I have a gmail address, I shall try it.
Message 22 of 28
I have just read my email in my gmail account, which registers it has been sent from my bt Internet address, and directs the recipient to reply to outlook.com
Message 23 of 28
Hi @HelenS,
Thank you for posting. Would you be able to take a screenshot of the message that directs the recipient to outlook.com?
Please make sure to edit out the first part of the email address before posting the screenshot on the Community.
Thanks,
Paddy
Message 24 of 28
I’ll try but my skills are very limited!
Message 25 of 28
I’m afraid to say my skills are not up to it. I can tell you it very clearly shows the sender’s email address (btinternet.com) followed by Reply to with my [email protected]
Message 26 of 28
With the BTYahoo email before the migration to BT mail, it was possible to set a reply-to address. It would appear that you probably inadvertently set this and it has carried over with the migration. However, the migration was completed many months ago so this problem must have been happening for some time.
I think this is going to need the mods to fix. They have already posted on the thread so should pick it up.
Message 27 of 28
The problem has been around for ages it’s true. Thank you for all your input.
Message 28 of 28
Hi @HelenS,
If you send me your details, I'll be able to get the email team to investigate.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
