Message 11 of 15
Re: hub 6
it appears that the 2.4gh wireless is not working. it says it is on in the advanced settings but shows off on the home page
Message 12 of 15
Re: hub 6
is there any way to turn it on or do i need a new hub?
Message 13 of 15
Re: hub 6
Try a factory reset first. If that does not fix it, then it means that the 2.4GHz wireless module is faulty, and you would need a replacement home hub.
Message 14 of 15
Re: hub 6
just done a factory reset, no change.
do i need to contact bt to change the hub?
Message 15 of 15
Re: hub 6
if you did factory reset by pressing and holding recessed button on back 20/30 secs until light flash and there is still a problem then phone 150 and request a replacement
