Message 1 of 13
my BT app, it is not available on my android Phone
Hi all,
I have a phone which was running Android 10.  I went to play store, search for my BT app but I couldn't see it available for installation.  Where am I supposed to find the app and install it?
12 REPLIES 12
Message 2 of 13
Re: my BT app, it is not available on my android Phone
I found it easily enough in Google Play. Does this link help?
Message 3 of 13
Thanks for your answer.  Putting in my BT as a search keyword was what I did.  However, I couldn't see any BT app which is developed by BT Group.  I saw BT email and BT Cloud but not my BT.
Is there anything wrong with my Android if it is only my problem?
Message 4 of 13
Just put BT as the search and the My BT app is at the top of the list.
Message 5 of 13
Did you try the link I posted in Message 2? That should take you direct to a list of BT apps as described by @licquorice .
Message 6 of 13
Hi all,
Thanks for all the replies.  However, I couldn't see any my BT in the list while I was searching for bt in the Google Play store.  None of them looks like my BT which is from BT Group.
Is there something else I could do like getting the apk somewhere else or install other stores?
Message 7 of 13
Did you try using the link posted by @pottyperson
Message 8 of 13
Perhaps Google Play Store considers you not to be using a UK account  or UK based for some reason.
Message 9 of 13
Looks that way.
@ramfong  Are you using a VPN? Are you in the UK?
Message 10 of 13
Hi,
I am currently in UK.  I turned off the VPN and I still couldn't find the my BT app.  The google play store location is probably the cause.  Let me find another phone and try it out with a UK play store.
