Message 11 of 19
Re: no landline
number 6
Message 12 of 19
Re: no landline
The term 'Landline' is used very loosely, some folks take it to mean a telephony service others the physical pair of wires to the house.
Message 13 of 19
Re: no landline
@weesmokey39 wrote:
number 6
if you connect the hub to the top socket on master what colour is the hub light?
Message 14 of 19
Re: no landline
flashing green-blue (15 secs) yellow then orange with permanent flashing broadband symbol
Message 15 of 19
Re: no landline
Hi @weesmokey39,
Thank you for posting and welcome to the Community. I'm sorry if you've been left without service.
When your order was placed was this a home move or did you move your service from another provider? I'd like to take a look at what is happening with your order.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 16 of 19
Re: no landline
Just finished 2 yr contract …..signed up as new customer for broadband +landline (new number)
Message 17 of 19
Re: no landline
Hi @weesmokey39,
Thank you for posting back and for sending in your details. One of the team will take a look at this and get in touch with you directly.
Out of interest when you try the phone do you get a dial tone or is the line completely dead?
Thanks,
Paddy
Message 18 of 19
Re: no landline
completely dead
Message 19 of 19
Re: no landline update
Everythings been running good since bt found an external fault to landline engineer was in attendance for some time and fixed the problem explaining in  layman's terms why he kept disapearing now and again (local communications box) i'm glad i visited the bt community link as i was getting knowwhere on chat and phone calls thanks Paddy and community for all the help given cheers
