Message 11 of 18
Re: smart hub 2 is flashing purple
@qian06  That is just a battery backup unit for the ONT. What is the white box to the left of your original picture.
Message 12 of 18
I have solved the problem! Thank you!
Message 13 of 18
@qian06 wrote:
No, that is just the battery backup unit for the modem. The modem itself is missing, you should have something like the unit on the left of the picture as well, that is where that green connector should be connected to.
Message 14 of 18
So where was the modem, had you removed it by mistake?
Message 15 of 18
Yes!!!
Message 16 of 18
Oh dear, hopefully all will be well but optical connectors should ideally be cleaned with specialist tools each time they are plugged in.
Message 17 of 18
Thank you for your kindly reminder.
I will check if the website is getting well.
Message 18 of 18
The internet is fast now.
Hope it will work afterward.
