Message 21 of 49
Re: watching BT Sport on a laptop
I have tried 4 different browsers, 2 laptops and a desktop and it's useless on the lot. The thing is I can't seem to get any help from BT to correct the problem wherever that problem lies. As I have said, it's not a problem with any other media/service, such as Sky, BBC etc.,
One thing to consider is what is it about your set up that remains the same whatever device and browser you use.  Are you using a standard BT Home Hub for example?  Are you using wi-fi extenders or connecting directly to the router?
Message 22 of 49
BT Home Hub 6,  WiFi, connection in the house.
As I have mentioned earlier the laptops and desktop all work fine for all other channels and services,  except for BT.  This is the only constant that I can confirm.  I have basically done all that BT have said to do and it doesn't work and there are others who have the same problem.
Message 23 of 49
I can view BT Sport on Edge and the Windows 10 app without issue via the Home Hub 6 and wi-fi. Curious why some can't access the service.
Message 24 of 49
Yes, I reported that earlier but the chappie wants to log into Sport directly from his Browser rather than use the app which continues to work superbly across Windows, iOS devices and our two Smart TVs, one Sony and the other Samsung.
Message 25 of 49
I haven't used the BT TV app for desktop, because apparently I got to have a set box or additional subscription to what I already have?  I pay £55 monthly to BT as things stand so don't particularly want to pay extra just to watch a footie match.   I have been connecting direct off my browser as I was advised to do.   But it's a terrible service. I have practically given up on it now and feel it best to cancel the whole BT package as my contract has ended.
Message 26 of 49
Actually there is a dedicated BT Sport app in the Windows 10 store. It's limited, and due to be discontinued soon, but the quality is pretty good.
Message 27 of 49
That's what I use and it is fine.
Message 28 of 49
Hi,   just want to update on this problem.  I have today downloaded the BT Sport app in the Windows 10 store, and it is now working perfect.  It's a free download.  No buffering, jumping or freezing.  Apparently this app is due to end, and I don't know what will happen then, but for now it's fixed my problem.  I hope this helps you sort your problem out.
Cheers
Message 29 of 49
Also success
As you say dont know what will happen when this is stopped.
Still strange app works ok but website doesn't when BT recommend using website
Message 30 of 49
Glad to hear it's working OK for you too. My thoughts entirely that it's strange how come BT recommended using the website, but it doesn't work, but the app does.  Strange.  The difference between the two is like night and day.   App works superb, sharp picture and clear sound.
Does anybody know when this app is due to finish?  Will there be an alternative then?
