Message 11 of 26
Re: zero upload speed so cant work from home. HELP!
@mrunhappy1 wrote:
Pls advise how to get screen shot
Using windows 10
Use the snipping tool (rectangular snip). You can then edit it by using the marker pen tool to blank out the phone. Then post it to this forum using the camera icon on the forum editor toolbar.
Message 12 of 26
Message 13 of 26
Message 14 of 26
On standard ADSL, 0.45Mbs is all you are likely to get.
If you can provide the full connection information from the home hub, then it will become clearer whether you are on ADSL or ADSL2+, which normally gives a faster upload speed.
Message 15 of 26
Home Hub 4
Message 16 of 26
sorry these stats give little helpful information  can you try
http://bthomehub.home  admin password is on the card on the back of the hub.
From the top Menu > Troubleshooting
> Helpdesk
> Bandwidth
You may be able to gain a little more information from the event log, such as the SNR Margin, shortly after a resync.
Troubleshooting >
Event Log >
Category 'WAN'
Message 17 of 26
Message 18 of 26
@mrunhappy1
You are only on ADSL Max, so you may possibly benefit by regrading to ADSL2+ which normally gives a better upload speed.
Message 19 of 26
Message 20 of 26
@mrunhappy1
Use Snipping Tool
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
