Message 1 of 5
BT 8600 shows a picture of a phone a red cross and the word FULL
Hi,
Our BT 8600 shows a picture of a phone a red cross and the word FULL, see picture.
It seems to work OK but I wondered what it means.
BT8600BT8600
I've looked in the manual, but it doesn't seem to be mentioned, any help would be appreciated.
Regards,
Paul
4 REPLIES 4
Message 2 of 5
Re: BT 8600 shows a picture of a phone a red cross and the word FULL
Either the answering machine is full of messages or your contact list is full at a guess.
Message 3 of 5
Thanks,
If I press Delete on the Answer Phone it says:-
"You have no Old messages"
I'll try and add a new contact and see what happens.
I'll let you know how I get on.
Anonymous
Not applicable
Message 4 of 5
That's the Missed Calls indicator. Presumably you haven't been deleting them & the memory allocated to that function is now full.
Message 5 of 5
Thankyou.
All calls now deleted and Indicator has gone.
