Message 1 of 2
BT Baby Monitor 6000
Hello all,
I’ve recently been given the purple bt smart baby monitor 6000, it has been previously used and I am able to connect camera to the parent screen and use it that way but for some reason I cannot link the kit to the BT smart controls app. I’ve tried the unlinking camera trick (holding link turning device off and on) but there was only s beep from the parent screen, nothing coming up on the app. Hopefully that makes sense, has anyone else had this? If so, have you solved it and how?
1 REPLY 1
Message 2 of 2
Re: BT Baby Monitor 6000
Hi, there’s 2 types of BT 6000 baby monitors one you can use parent screen and the app and one you can only use the parent screen. You may have the one I have which doesn’t connect to the app, hope this helps
