Message 1 of 6
BT Baby Monitor 6000 - Screen stopped working
I have a BT Baby Monitor 6000. The screen suddenly stopped working although one green light was on in the side panel.
Having read a number of posts, i let the battery drain to see if it might start back up. Nothing.
I then held down the menu and power buttons after re-charging it thinking this might reset. It blinked. But now i have one red light and 2 green lights - something i cannot find any information on online so no idea whats wrong with it.
Anyone had that issue? Thanks
5 REPLIES 5
Message 2 of 6
Re: BT Baby Monitor 6000 - Screen stopped working
@sunit1000
Try
Product helpdesk information
If your product is within warranty:
By phone: 0808 100 6554
Monday to Friday 9.00am to 5.30pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
Spares information
Replacement parts are available from the product helpdesk, but please note the battery is sealed and is not user replaceable.
Message 3 of 6
it is not within warranty but is less than 2yrs old
Message 4 of 6
Hi @sunit1000 and thanks for the reply.
Your best bet would be to contact the out of warranty number as posted by @Keith_Beddoe .
Cheers
David
Message 5 of 6
Hi @sunit1000, did you get anywhere with this situation?
my monitor is no longer in warranty but as it was a replacement for my last faulty monitor it is only 14 months old.
But no one seems to be able to help me.
Message 6 of 6
Did you get a solution? It says solved but just has a bunch of way to contact support.
