Message 11 of 39
Re: BT Smart Hub 2 USB port
@Earthling said:
It seems this SSD is an SCSI drive.  Might that be the reason it cannot connect to the Smart Hub 2 but can connect to PCs and laptops?
Erm...really?
How are you connecting the SSD drive, is it via some SATA to USB cable? I mean you can get an SSD inside an SCSI enclosure, SCSI just really being the interface, but you are mentioning USB?
Can you explain what you have?
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 12 of 39
This is the cable I'm using.  Works fine when connecting the drive to a computer but I was hoping to connect  it to the USB port on the SH2 but it isn't being seen by the SH2.
Message 13 of 39
Yeh but the SSD itself then, this is just an SSD inside a USB-C enclosure?
Does it have any light indicators on it to suggest its being powered up?
Message 14 of 39
This is  the SSD.  Up to now I've kept a standard HDD in the SH2 port and was simply hoping to upgrade to SSD.  No external lights but I have checked that the port has power
Message 15 of 39
Most USB HDD drive issues I come across are down to power, IE there not being enough to power the attached device, even SSD's can sometimes suffer from this even if their power footprint is smaller than a HDD....which for you currently works. That is why I was interested if it was powering up the USB SSD.
I think the issue may be more nuanced though, I'm a little out of my depth now as I dont know the specifics of the SH2 USB port, but it wont be a compatible as a USB port through a typical windows system.
The drive is apparently an NVMe with a USB-C interface which you are converting to USB-A, now that shouldnt be an issue and yes everything should be backwards compatible, but I doubt this drive was ever designed with a USB2.0 port in mind and further still one attached to a router. Have you tried the included USB-C to USB-A adapter rather than the cable you have bought separately ?
Anyway, other folks on here will probably be able to answer further, I have zero experience of using the SH2 USB port, im just talking from a general computing angle.
Message 16 of 39
If there was an included adapter I must have lost it.  The ad doesn't mention it though as far as I can see.  I you look at my #5 lack of power was my first guess but the port does  power up other external drives so that isn't the issue.  Also, the HDD I was using previously had its own power adapter.
Message 17 of 39
Just looks like on that Amazon listing there is a USB-C to A.
Message 18 of 39
Thanks, I'll go have another mooch
Message 19 of 39
A USB-C to USB-A cable should yield the same results, but its worth a shot.
Message 20 of 39
@Earthling please delete the links to Amazon, it is against forum rules.
