Message 21 of 39
Re: BT Smart Hub 2 USB port
I would if I could but no edit option now.  Maybe a mod would do it for me.  Sorry about breaking the rules, wasn't intentional,
Message 22 of 39
OK, found the adapter but it hasn't changed anything
Message 23 of 39
You already have a HDD working right with it, in which case I just think there is a compatibility issue between the new drive you have and the SH2.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 24 of 39
Certainly a strange one. Probably no consolation but I have a 2Gb Toshiba drive that works just fine powered by the hub usb port.
Message 25 of 39
Does that have a native USB-C interface?
Message 26 of 39
Yes, it does.
Message 27 of 39
Im out of ideas really other than this particular drive is problematic.
Message 28 of 39
Just a thought.
I have seen this before with cheap asian cables.  I take it the end plugged into the SH2 is USB 3?  While USB 3 is supposed to be backward compatible with a USB 2 socket, the cheap cables are not built quite precisely enough.  I had such a cable once where I had to ease it very slightly out of the socket to establish an connection between the USB 3 cable and the USB 2 socket.
Message 29 of 39
Yeah it will be because its a USB-C to USB-A cable which he got separately, at least it looks that way, it would be USB 3 at the A end.
The external SSD comes with its own USB-C to USB-C cable but also an adapter to covert one end to USB-A.
Message 30 of 39
Even so I've found the idea of backwards compatibility with these cables to be a bit hit & miss.
