Message 1 of 16
BT Smart Hub 3
I have FTTP (with internal modem) box with a Port 1 outlet.
I live out in the sticks (limited mobile signal coverage) and have only in the last 2 months (due to another mobile mast/tower going up) have had 1 bar (outside and inside) of 4g/5g mobile coverage and prior to this did need the BT Digital Voice headset with the Smart Hub 2.
I deregistered the Headsets from the SH2 on the headset itself and checked in the SH2 Hub Manager > phone section.
I have now setup the BT Smart Hub 3 (Wifi 6 standard) and when combined with WiFi Calling (on mobile) I can now make/receive mobile calls in the property without needing the BT Digital Voice.
I called BT and they cannot perform line tests/refreshes with the BT Smart Hub 3 and they see the SH3 as a 3rd party router. And BT said that the BT Headset (WPS) is DECT so can be used on Wifi 5/6/7 (does not matter)
After repeatedly trying/failing to pair the Headset to SH3 via WPS (I tried pressing for 2 seconds as instructed on the Headset then 7 seconds when that failed)  I think the reason this fails is :
1) The SH3 is not setup for Digital Voice (the SH3 Hub Manager has no Phone section whereas the SH2 has a phone section)
2) BT's inability to recognize (in terms of device management) the SH3 '3rd party router'
3) both.
I could revert from the SH3 to the SH2 and use the black disc extenders but the SH3's wifi is much faster and I would rather stick with SH3. My computers recognize the SH3 wifi much faster than the SH2.
So as of now I would like to stick with the SH3 but sadly can't use Digital Voice and, although the SH3 has the legacy green 'phone' port (which I could connect a standard landline phone into) BT's inability to recognize the SH3 probably means that a landline phone used with SH3 won't work either.
If BT see any router other than the SH or SH2 (which are their latest routers) as a 3rd party router I may aswell go all the way and get a top of the range WiFi 7 standard business router with external antennas. Maybe a Wifi 7 gaming router like the ASUS TUF BE6500 Wi-Fi 7 Dual Band TUF Gaming Router?
15 REPLIES 15
Message 2 of 16
Re: BT Smart Hub 3
It's not a generic problem, I de-registered 2 handsets from my SH2 and registered them to a SH3.
Try a factory reset of the hub.
Message 3 of 16
Re: BT Smart Hub 3
"1) The SH3 is not setup for Digital Voice (the SH3 Hub Manager has no Phone section whereas the SH2 has a phone section)"
Where did you get the SH3 from?  That sounds suspiciously like the Business SH3 which, unlike the home version, does not support DV, (even though I believe some of them have a redundant phone socket).
Message 4 of 16
Re: BT Smart Hub 3
The BT hub is 'BT business smart hub 3 F5394-CP' and is described as the BT Business Smart Hub 3
Message 5 of 16
Re: BT Smart Hub 3
I factory reset the SH3 (BT SH3 F5394-CP)  right at the start and it made no difference. Does the SH3 being BT SH3 F5394-CP mean that it does not support Digital Voice? BT had no idea
Message 6 of 16
Re: BT Smart Hub 3
Message 7 of 16
Re: BT Smart Hub 3
Ok then BT SH3 has no Digital Voice.
Is there an equivalent EE Wifi 7 router that has a long range and that also supports DV?
Message 8 of 16
Re: BT Smart Hub 3
Message 9 of 16
Re: BT Smart Hub 3
I believe so, but I'm not familiar with the EE equipment.
There is an EE forum & I'm sure JimM11 will be able to tell you, here:
https://community.ee.co.uk/t5/Broadband-Landline/bd-p/broadband
Message 10 of 16
Re: BT Smart Hub 3
I was not told that ALL EE routers do not work with Digital Voice. As the previous statement conflicts with a lot of EE website information that claims that EE routers do support Digital Voice.
A variant of the question is: Would a EE Digital Voice phone (they exist) work with a EE router in this property (which has a BT line with Digital Voice)?
