Message 1 of 11
Extra Box
I’ve just switched over to BT from Sky with whom we had an remote box in the bedroom which simply used wifi to connect with our main Q box downstairs. Does the BT Extra box work in the same way or does it require its own aerial connection? Thanks.
10 REPLIES 10
Message 2 of 11
Re: Extra Box
Hi, @Ridgewoodwoody Welcome to the community and thanks for posting. The extra box needs to be connected to the internet via ethernet or mini connectors and it will also need its own aerial connection.
Neil
Message 3 of 11
Re: Extra Box
Ah. Our hub is a long way from where the extra box would be, so that rules it out.
Message 4 of 11
Re: Extra Box
@Ridgewoodwoody As part of the extra box order, you can ask for BT Mini Connectors for BT TV | BT Help overcome that.
Neil
Message 5 of 11
Re: Extra Box
Thanks, Neil. Crikey they're a bit of a price. Are there any third party ones?
Message 6 of 11
Re: Extra Box
It all depends what you want to watch on the extra box, there aren't many programmes on Freeview these days that can't be viewed live without an aerial using the relevant app.
For example BBC programmes can be viewed live on BBC iplayer and ITV programmes can be viewed live on ITV hub, neither require an aerial and there are also apps for channel 4, channel 5 and UK TV.
Message 7 of 11
Re: Extra Box
@Ridgewoodwoody If you order them at the same time as you order the extra box you get them at a discounted rate.  I believe they're around £10 when you're a BT TV customer.
There are third party ones too but we can't offer technical support if anything should go wrong with them.
Neil
Message 8 of 11
Re: Extra Box
OK. That's more like it. How do I order these together?
Message 9 of 11
Re: Extra Box
@Ridgewoodwoody You can order both together by calling the value team on 0800800150.
Neil
Message 10 of 11
Re: Extra Box
That’s great. Thanks for all your advice.
