Message 1 of 8
How do I factory reset my BT8500 Base station when none of my phones are registered to it and the pi
How do I factory reset my BT8500 Base station when none of my phones are registered to it and the pin in not known?
7 REPLIES 7
Message 2 of 8
Re: How do I factory reset my BT8500 Base station when none of my phones are registered to it and th
@Johnsoap
The helpdesk should be able to advise. There may be a reset button on the base unit.
Product helpdesk information
If your phone is within warranty:
By phone: 0800 145 6789
Monday to Friday 9.00am to 5.30pm, Saturday 9am to 2pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
Message 3 of 8
@Johnsoap  Have you considered consulting the manual?
Page 56
Reset the handset or base settings
2. Press to highlight Reset, press Select.
3. H/set settings is highlighted. Press Select or press to highlight Base
settings and then press Select.
4. Reset <handset or base> settings back to default? is displayed, select Yes.
5. Resetting <handset or base> settings... is displayed while the reset takes place.
Once finished, <handset or base> settings reset back to default is displayed.
Clear the
Message 4 of 8
Please note everyone - I have read the manual! the manual tells me to use a handset to reset either a phone or the base  station!  None of my phones are registered to the base station so i dont have a phone capable of talking to the bases - I cant register any phone to the base because the system pin is not known!
So, how do I reset the base back to the factory defaults!
Message 5 of 8
Fatal flaw. You can't without a hand set unless the phone numbers supplied in message 2 can offer some help.
Message 6 of 8
Yes I have been through the manual. When it asks for my PIN I put 0000 but that is rejected. I can not go further.
Message 7 of 8
I tried this email. It does not work.
Message 8 of 8
@Bakker1219
You are posting on a thread that is almost 3 years old and may not have upto date informaton.
You would be better to post on your own thread where you may get some relevant replies.
