Message 1 of 12
How to add additional camera to BT Smart Baby Monitor with 5 inch screen?
How do I add an additional camera to my BT Smart Baby monitor?
I have read lots of previous posts with the same issue and there doesn't seem to be a solution!
My monitor lights flash green for approximately 20 seconds when trying to pair with the additional camera and then then beeps for around 5 seconds resulting in an epic fail to connect.
11 REPLIES 11
Message 2 of 12
Re: How to add additional camera to BT Smart Baby Monitor with 5 inch screen?
Hi @Martyn2909,
Thank you for posting. Have you tried the step from this thread - Linking additional camera to baby monitor 6000
If that doesn't work, I would give the product helpdesk a call. The details are -
Product helpdesk information
If your product is within warranty:
By phone: 0808 100 6554
Monday to Friday 9am to 5.30pm
Saturday 9am to 2pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
Thanks,
Paddy
Message 3 of 12
Yes I have tried the steps in the suggested thread and still doesn't add an additional camera
Message 4 of 12
@Martyn2909  did you find a resolution to this? I am trying to find out how to do this before I buy an additional camera as I want to make sure what I get is compatible!
Message 5 of 12
After trying all the suggested ways to connect, it just did not work. I ended up just getting a new separate monitor and camera. Very disappointing result I'm afraid
Message 6 of 12
Hi,
Also tried this but it doesnt work. I have the BT Smart Baby Monitor with 5 inch screen, trying to connect an additional camera (6000 model) but its not happening 😞
Message 7 of 12
Hi @Tomhampson Check out message 7 on this thread.
Neil
Message 8 of 12
"Unfortunately the BM6000 camera is not compatible with your BM 5in monitor you will need a BM5IN Camera in order to link an additional camera"
Message 9 of 12
HI @Neil0 - I mailed support and posted my reply below, No go for my camera/monitor combo.
Message 10 of 12
@Tomhampson I'm sorry to hear that, thanks for updating the thread.
Neil
