Message 11 of 15
Re: Line Cord Error, please check with Premium Phone Trio
Hi @lesleyp118, keep us updated and if you need more help to get this fixed we'll be happy to help.
Cheers
John
Message 12 of 15
Well, whatever it was, BT have magically fixed it from afar, and we now have working phones 😃. No explanation as to what it was, or whether it's likely to happen again . But if it does, I will report it immediately rather than consider it might be a fault with the handsets and waste so much time 😁
Thanks to all of you who gave me help and suggestions along the way. 🙏
Message 13 of 15
It was most likely faulty equipment in the exchange, its all getting old and worn out, hence the move to BT Digital Voice.
Message 14 of 15
Hi @lesleyp118, thanks for the update and good to know you're not back in service 🙂
Cheers
John
Message 15 of 15
I have the same problem and have reached the same stage where an Engineer should be coming out on Monday. The Master Socket into the house is like number 6 in the previous diagram.
I first had this issue over a week ago and it rectified itself overnight but returned last Monday BT say there are no issues in the area.
