Message 11 of 17
Re: New BT/EE smart hub
Yep. 2.5Gbps WAN, 4x1Gbps LAN.
Message 12 of 17
Yeah realise this now after doing some digging last night.
What idiot decided that was a good idea? Seems a bit shady to be honest.
Tempted to just cancel the plan and roll down to 900...or buy a router/switch that has the multigig ports.
Message 13 of 17
Is that through BT or EE?
Message 14 of 17
1.6Gbps is only available via EE
Message 15 of 17
EE are rumoured to be launching another new router next year with Wifi 7
Hopefully that'll have more than just the WAN port as 2.5 gig, It might be worth trying to get that from them when it launches if you are the 1.6gbps package
Message 16 of 17
Hello I have renewed my BT broadband in an EE shop, the have sent me a EE smart hub I have set this up and its working however seems slower that the BTHub5 that I had.  Is this correct or should I go back to the BTHub5
Message 17 of 17
Slower in what way? What are you measuring?
