Message 3 of 7
Pairing infrared 4k Recordable box remote with pro box
Hi, I have a remote coming for the 4k Recordable  box to use with my BT pro box so that it will control my Hisense tv volume etc via infrared as I have read on many a post here they work. Is there anything I need to do to pair the remote to my BT pro box? I have the hisense code ready to pair it with my TV.
6 REPLIES 6
Message 1 of 7
Re: Pro Box IR Remote Support?
Hi,
Message 2 of 7
Pairing 4k Recordable box remote with pro box
Anonymous
Not applicable
Message 4 of 7
If it's new it should just work. Humax do have two IR code sets so that you can have two boxes in the same room without conflict, so if it's a used remote there's an outside chance it could be set to the second code set.
Message 5 of 7
Thanks for the reply.
I managed to persuade BT to send me one out so hopefully its brand new or reconditioned like new and reset and should just work
Message 6 of 7
I have moved your posts about your problem onto your own thread. Posting on multiple threads causes confusion and duplication of replies.
Message 7 of 7
@Anonymous Humax (including BT branded) Youview boxes use a single  Humax remote IR code which is not changeable. There is not the option to change it as is the case with some other Humax recorders.
@Spurs1  the remote for the BT 4K box (T4000) will also control  the BT Pro box  (Sagemcom) if it is in line of sight.
