Message 1 of 6
What is a warm reset?
My BT Smarthub  underwent a warm reset. What is that?
How does it come about?
Wren
5 REPLIES 5
Message 2 of 6
Re: What is a warm reset?
A "warm reset" is simply powering the hub down then restarting it or put another way... switch it off and on.
Edit: This can be instigated by the owner or remotely by BT for instance when a software update is installed.
Message 3 of 6
I have not instigated a reset and there is no evidence of a software update. Where would I look to see if this was the case?
Wren
Message 4 of 6
As @gg30340  has said, its probably been done by BT.
Message 5 of 6
Wren
Advanced settings > Technical Log > Event log  look for CWMP events
Message 6 of 6
I cannot see anything relating to CWMP. But then I cannot say I understand what the event log is telling me.
I think I have a Smarthub-1 and it is running firmware version SG4B1000E077 tha was updated when I installed this hub on 9th March 2022.
Is this correct?
How do I get help with interpreting the event log?
Wren
