Message 1 of 3
Recording Programmes
Hi all, just after a bit of help as I’m new to BT……..but I’ve set programmes to record, series mainly and mainly sky and ITV, there should be approx 10/15 programmes on my list to watch but it only shows the last 6, why aren’t the others there ? Am I supposed to look somewhere else ? Any help greatly appreciated, Thanks.
2 REPLIES 2
Message 2 of 3
Re: Recording Programmes
Hi @Juwoo1406
 I suspect you are looking at the RECORDINGS AND WATCHLIST  on the home page.
That carousel  I think is limited to the most recent  10-15 or so programmes that you are seeing  , so to see all you need to select the +MYTV box at the beginning of the list and you will then get  the option to view view the full list  RECORDINGS , Watchlist  and SCheduled on separate pages,
Message 3 of 3
@zulu17  Thanks so much for your help, now I can see all my recordings, just different to what I’m used to…….much appreciated 🙂
