Message 1 of 4
Virgin with BT Whole home discs
Hello
I have Virgin Media broadband and use 6 BT mini discs to take Wi-Fi around my home.
The kids bedrooms seem slow so I was wondering
Can I take a cable from my router and run it into my loft then use Netgear 5 port gigabit network switch to run to the discs in each of the 4 bedrooms.
Will this work?
Thanks Tony
3 REPLIES 3
Message 2 of 4
Re: Virgin with BT Whole home discs
@abmunro
Welcome to this user forum for BT Retail phone and broadband customers.
It would be best to give the WHW product helpdesk a call on 0808 100 6116 ( Mon to Fri 9am to 5.30pm and Sat 9am to 2pm) or drop them an email to: [email protected] and they'll be happy to help.
You may also like to ask for advice on the Virgin Media forum.
https://community.virginmedia.com/
Message 3 of 4
My guess is yes, you can.
Effectively you would be connecting all six discs directly to the hub which, according to BT Whole Home Wi-Fi FAQs - Set-up and installation | BT Help is permissible.
"Can I connect more than one disc to my hub (router) using the Ethernet cables?
If you're using Whole Home Wi-Fi or Mini Whole Home Wi-Fi, you can. If you wish, you can locate a disc a long distance from your hub (router)"
Message 4 of 4
While it should work, you may be supplying too much WiFi.  It's worth testing but unless the house has solid granite walls, you'll probably get better performance using fewer discs!
I only learn by making mistakes and owning up to them - boy do I learn a lot!
