Message 1 of 4
Virgin with BT Whole home discs
Hello
I have Virgin Media broadband and use 6 BT mini discs to take Wi-Fi around my home.
The kids bedrooms seem slow so I was wondering
Can I take a cable from my router and run it into my loft then use Netgear 5 port gigabit network switch to run to the discs in each of the 4 bedrooms.
Will this work?
Thanks Tony
3 REPLIES 3
Message 2 of 4
Re: Virgin with BT Whole home discs
@abmunro
Welcome to this user forum for BT Retail phone and broadband customers.
It would be best to give the WHW product helpdesk a call on 0808 100 6116 ( Mon to Fri 9am to 5.30pm and Sat 9am to 2pm) or drop them an email to: [email protected] and they'll be happy to help.
You may also like to ask for advice on the Virgin Media forum.
https://community.virginmedia.com/
Message 3 of 4
My guess is yes, you can.
Effectively you would be connecting all six discs directly to the hub which, according to BT Whole Home Wi-Fi FAQs - Set-up and installation | BT Help is permissible.
"Can I connect more than one disc to my hub (router) using the Ethernet cables?
If you're using Whole Home Wi-Fi or Mini Whole Home Wi-Fi, you can. If you wish, you can locate a disc a long distance from your hub (router)"
Message 4 of 4
While it should work, you may be supplying too much WiFi.  It's worth testing but unless the house has solid granite walls, you'll probably get better performance using fewer discs!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
