Message 11 of 31
Re: Whole Home Wifi Premium cannot see devices connected to wifi / ethernet when on other connection
I've not got anything other than default settings in the subnet mask.
Message 12 of 31
You can only have one disc connected to the router with the premium system, any other discs which for whatever reason also require an ethernet connection should be daisy chained off of one of the others, assuming that this is how you have yours setup then it sounds like a factory reset of one or other (or maybe both) is in order.
There will almost certainly be a method for backing up the router settings so that you can re-instate them with minimal effort and it would appear that there is also a way of backing up the Wholehome system
What is Backup and restore in the app?
This function lets you save your Whole Home Wi-Fi settings such as disc and wi-fi network names.
If required, you can then factory reset your system and automatically restore your original settings, just follow the app instructions.
BT Whole Home Wi-Fi FAQs - Whole Home Wi-Fi app | BT Help
Message 13 of 31
Yeah, the backup and restore worked fine.
Only 1 disc is connected to the router and the other disc is connected via WiFi backbone. The discs and WiFi all work fine in isolation.
And I've done a full factory reset on both discs and the problem still remains.
Message 14 of 31
It's sounding more and more like a router problem especially as you say it works OK with the BT router
Message 15 of 31
I think you might be right. Any ideas what setting I need to be looking for and checking on the Sky router?
Message 16 of 31
You might be better off asking that question here The Official Sky Help Forum | Sky Community
Message 17 of 31
Ha ha - I'm 100% sure they'll say it's a whole home issue too!!!
Message 18 of 31
@Cocksy
Try the product helpdesk.
Product helpdesk information
If your product is within warranty:
By phone: 0808 100 6116
Monday to Friday 9.00am to 5.30pm
Saturday 9.00am to 2.00pm
By email: [email protected]
If your product is out of warranty, please call the Technical Help and Support Desk on 0808 100 6116
Message 19 of 31
Probably but you've already proved that the WholeHome system works with the BT router so you know that's not the case.
Which Sky hub do you have
Message 20 of 31
The BT SH2 uses IPs of the range 192.168.1.x by default. So when you were using the BT SH2 did you either:
  1. Change the IP range of the Whole Home Wifi Premium to 192.168.1.x to fit the BT SH2, or
  2. Change the IP range of the BT SH2 to 192.168.0.x to fit the Whole Home Wifi Premium?
When the Sky router arrive it presumably was using IPs of the range 192.168.0.x ?
If so, it would clash with a. but mesh with b.
Or something along those lines.
