Message 11 of 24
Re: cyberpower battery backup cable
Unfortunately, the guys on the EE forum seem unsure as well.
Is there a model number on that Cyberpower unit?
Message 12 of 24
Yea I didn't realise there was a cable missing because I set it up when we didn't have full fibre installed, I assumed the 2nd battery was just another backup.
You'd think when they installed full fibre they could have set it up for that. I think they gave us 2 batteries because full fibre was scheduled to be installed. But the instructions only showed for the way I installed it, and they didn't have the cable I needed for the smart hub.
I contacted them this evening though, they're gonna send the 'battery backup plus' which will have a splitter cable that powers both. They did send me out a lead a few days ago, but it was for the battery backup plus, they couldn't seem to get the older battery backup cable.
Thanks for your help, much appreciated 👍
Message 13 of 24
Yes, that's what I suspect the one in the link was for, which is why I couldn't be sure it was the one you needed.
Do you have a model number on the one you already have?  This question has come up a few times and I'd like to get to the bottom of it.  If I have a model number I can query it with CyberPower's own support people.
Message 14 of 24
Yes I just looked & had a picture of the model number, it is 'DTB24U12V'
Hopefully you'll get some answers, I would like to purchase the lead if possible so we have a backup for our backup 🤣
Message 15 of 24
Thanks.  I'll see what I can find out but it will probably take the best part of next week.
Message 16 of 24
Just had some feedback from a friend on the EE forum.
"The connector for the back off the CyberPower BBU is the same as the one for the BT Smart Hub 2, Barrel connector 5.5/3.0mm and for anyone who needs the output of the CyberPower is 12V Centre +ve on the cable."
Message 17 of 24
That's great, thanks for the heads up.
I did a quick search & can't find any specific to those requirements, I'll take a better look later when I've more time to do so on the laptop.
Message 18 of 24
As I said before, 3.0mm is an unusual size.  You can buy the plugs and make up your own lead, if you know how.  Alternatively, buying something like a 2.1mm plug to plug lead and the a couple of 2.1 to 3.0 adapters might be easier.
Message 19 of 24
Yea I must actually buy those leads + adapters, I wouldn't attempt to make them myself 🤣
Message 20 of 24
I've had a reply from CyberPower support.   Apparently, it depends on the model:
