Message 1 of 5
voip phone stuck on synchronising handset
Hi all,
My Voip  phone stuck on synchronising handset ,
I had to reset the smart hub 2 so I lost all my settings and had to re-pair the wifi extender to the hub and also the phone to the hub but it just keeps displaying "Synchronising handset data" and the keypad won't do anything,
I then restarted the hub again still the same
Unable to contact anyone directly , help pages almost useless!
Doe's anyone know of a quick fix?
4 REPLIES 4
Message 2 of 5
Re: voip phone stuck on synchronising handset
Ok I found that if you hold the end call button down for a few seconds you can switch the phone off
then restart it  and it goes through the welcome screen and it all seems to work ok now.
Message 3 of 5
Brilliant. Nothing about this in any manual of course. The whole system is very flaky and obviously not adequately tested.
Message 4 of 5
The end call key on the phone also shows the standard symbol for turn off
Message 5 of 5
This problem cropped up after more than a year with the Alexa handset.
Great solution, worked like a charm--except I didn't even need to restart the phone, as it just went directly back to the normal idle screen.
Thanks!
