Message 1 of 4
150 vs 300
Hi all,
I moved to BT from TT 15 days ago and i have the free speed boost which is giving me the speeds below, i don't need the speed and was happy with TT's 150 Mbps but if i drop to 100 Mbps the lowest limit BT guarantee it may be an issue, can i drop to 150 Mbps then move back if it doesn't work out?
Thanks in advance.
3 REPLIES 3
Message 2 of 4
Re: 150 vs 300
Full fibre isn't rate adaptive like FTTC, you will get the full speed, besides which, I very much doubt if you could tell the difference between 100Mbps and 150Mbps in the real world in any case.
 The 100Mbps figure is just an administrative figure.
Message 3 of 4
Re: 150 vs 300
Thanks that is the answer i was hoping for.
Message 4 of 4
Re: 150 vs 300
I've been on 150 FF for 12 months now.  Probably done more speed tests than ever before.  (Just curiosity).  151Mb/s down, 29Mb/s up every time.  Doesn't matter how many times I reboot the ONT.  Doesn't matter how often I reboot the router.  Does matter that I've changed router.  151 down, 29 up every test.  Solid as a rock.
