Message 1 of 14
1gb service not getting full upload speed
I've seen others report similar things, I started with the 500mb service, was offered the 1gb service for a reasable additional fee, but my upload speed remains at 50mb.
I have restarted all the equipment, and I am using the btwholesale speed tester and I am using an ethernet cable directly to the router, and I go have a gigabit ethernet card.
I made the mistake of calling the 'tech support' helpline, and was advised to renew my contract which shoulod reset the flags and give me full upload speed - but now that order is complete nothing has changed (suprise suprise!).
Others seem to have had success posting their exact same scenario here so I'm giving this a go first.
Yours hopefully,
Multiroom
13 REPLIES 13
Message 2 of 14
Re: 1gb service not getting full upload speed
Hi @Multiroom, welcome to the forum and thanks for your post.
Sorry your upload hasn't improved. Has your BT Hub been connected continuously for the last 72hrs?
Cheers
John
Message 3 of 14
I had the hub connected over the weekend, not for 72 hours though. And Now I'm back to third party hardware, bar the fibre Huwaii modem.
As for reintroducing the hub, it is a little inconvenient as I run a full Ubiquiti system throughout the property with multiple connections in and out throughout the day, and VPNs through to several offices I provide support for.
Is there any other way to overcome this? At a push I could setup a bunch of rules on the hub to bodge things for a few days, but I'd prefer not to if it wasn't essential.
Thanks for your reply.
Message 4 of 14
Are you a business user then?
Message 5 of 14
I provide support as a passtime, however some of my friends and family value the service I provide to them. I'm a residential user, operating from a residential address with a home account. My property is my technical playground, that about sums it up. Why do you ask? @Keith_Beddoe
Message 6 of 14
@Multiroom
Its just that if you had needed a better connection with a less contended connection, and a better SLA, then a BT Business connection may be more suitable.
Message 7 of 14
Ah, no - there's no urgency to this, I just want to get it sorted. Not least of all so that I can stream my own UHD movie library without having to transcode. I rip all of my movies at the highest bitrate, some of them are 80Mbps plus and with the 55Mbps limit that can't happen.
Message 8 of 14
@JohnC2 I've just connected the Hub and will leave until Thursday. I can work around the issues it'll bring, but in the meantime is there anything else I can do?
Many thanks
Message 9 of 14
Hi @Multiroom, the reason I asked is the hub is usually the cause of the 50Mb upload cap.
If you leave it connected and reply to the Private Message I sent you we'll be happy to get the upload fixed.
Cheers
John
Message 10 of 14
Thank you - I have replied as rewuested.
