Message 1 of 5
40/10 Speed Capped I want Fibre 1 HELP PLEASE
I am looking for some help please to upgrade my BB from fibre essentials to fibre 1 as i'd like any extra speed I can. Researching through some posts and getting a better myself a better understanding it looks like my line speed has been capped at 40/10 and therefore the estimate I get when selecting fibre 1 is the same 32-36mb.
I have checked the BT wholsesale website and it says my line should support faster than this?
VDSL Range A (Clean)
VDSL Range B (Impacted)
54.438.511.27.435AvailableAvailable--
533511730.2AvailableAvailable--
Router stats
Product code:Smart Hub 2
Serial number:+091298+2103019514
Firmware version:v0.30.01.08093-BT
Firmware updated:Thu Dec 9 21:13:02 2021
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:9 days,15 Hours26 Mins32 Secs
Data rate:9.999 Mbps / 39.999 Mbps
Maximum data rate:11.954 Mbps / 43.374 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:8.1 / 3.9
Line attenuation:11.6 / 20.2
Signal attenuation:11.6 / 27.5
VLAN id:101
Upstream error control:Off
Is there anyway I can upgrade as when I speak with the chat team they only tell me what I can see on the screen.
I dont mind paying a bit extra as with 3 kids at home even another 10mb would make a difference.
Thanks in advance for any help
4 REPLIES 4
Message 2 of 5
Re: 40/10 Speed Capped I want Fibre 1 HELP PLEASE
You can try customer options  0800 800 030  but looking at the router stats the max data rate is only 43.37 so you are only looking at a 3Mb gross uplift anyway so the cost may not be worthwhile.
Message 3 of 5
looking at you hub stats I agree with @conrad  you would not see much difference in connection speed with attainable at 43mb and noise margin already lower than normal at 3.9db.
save your money
Message 4 of 5
Agree, total waste of money. Difference in speed would be totally unnoticeable.
Message 5 of 5
Thank you all. I was hoping it might have been a bit more of an uplift than 3mb.
I am a complete novice at understanding this hence I thought I'd ask the experts.
Will have to look into 5g broadband next as unfortunately FTTP is not available in my area.
