Message 11 of 20
Re: Archer VR2100 on FTTP
In the connection settings where you chose PPPoE, make sure vlan tag is NOT ticked as enabled.
Message 12 of 20
It's greyed out and says "VLAN ID cannot be disabled when Ethernet Connection is enabled"
Message 13 of 20
I'll get back to this tomorrow and have another go, thank you much for your suggestions
Message 14 of 20
Hmm, odd. It ought to say VLAN ID cannot be enabled rather than disabled when Ethernet connection is enabled.
The VLAN tag 101 is a function of the modem (ONT in your case)
Message 15 of 20
I assume you rebooted the device after changing the operation mode from DSL modem mode to wireless router mode?
Message 16 of 20
Yes of course, I've made sure to reboot after every config change.
Message 18 of 20
I'll give it a go shortly, and many thanks and kudos all round!
Message 19 of 20
I finally got it working today. I have no idea why I was receiving the VLAN tag error but rebooting and resetting everything got rid of it. I did the setup over ethernet one more time and it worked. Thank you everyone, got there in the end!
Message 20 of 20
Glad you got it sorted.
