Message 11 of 18
Re: BT Broadband speeds reducing over time
no that's a filter used on the hub logs  you are in the advanced/technical logs and looking for advanced /technical information
you certainly have a connection problem with that number of connection drops.  Have you tried connecting to the test socket with a filter to see if that stabilises your conenction
Message 12 of 18
Is this it?Is this it?
Message 13 of 18
yes that's the stats.
is it possible to try test socket which is behind master socket faceplate?
if that does not stabilise your connection then you need to phone CS 150 and get engineer visit as your connection will not improve until you get a stable connection
Message 14 of 18
Thanks for you help, I'll try using the test socket for a few days and see what happens.
Message 15 of 18
Finally solved - turned out to be the faceplate / filter.
Using the test socket and plug in filter I had reliable broadband for over a month. (44Mb / 9.9Mb).
Refit the original faceplate / filter - no broadband at all.
Disconnect the extension wiring, no effect.
Back to test socket and plug in filter, all working again.
Bought replacement MK5C master socket from Amazon, plugged in faceplate / filter (with extension wiring disconnected) , again I had reliable broadband for over a month.
Reconnected the extension wiring, still have reliable broadband.
Message 16 of 18
Hi @Richard909,
Thank you for posting back to update the thread.
Thanks,
Paddy
Message 17 of 18
Started have speed and disconnect problems again in December 2022, new filter fitted again and problem solved once more.
Wondering if I'm just unlucky with the filters I'm getting.
Message 18 of 18
Those faceplates are notorious for causing issues, it only take a slight touch to cause it to become unseated. IMHO you would be better off with a NTE A back box and MK3 faceplate as this is screwed on.
