Message 21 of 24
Re: BT Fibre 500 to 900 Upgrade - No change to upload speed
The first place to start is with your own thread rather than posting in a solved one. Then give the FTTP team a ring.
0800 587 4787
Message 22 of 24
No probs, one of the mods picked up my message from the thread and looking into this and raised a complaint. Hopefully it will be resolved in a few days time. Cheers for the reply. S
Message 23 of 24
This happens quite a bit I suspect. I had the same issue and was given various platitudes about "things settling down" etc. but it was all down to a bad profile being set up. Makes one wonder...
Message 24 of 24
Yeah hopefully Openreach can fix it on their side as NeilO said BT side of things all looks good.
